Tim,
Welcome to the forums!
If you go into your system setup menu, the second screen you hit is labeled "Calibrate". it's explicitly there to teach the radio how far each stick will travel (signal wise). give it a go -- hiding settings in your trim is a fair workaround, but running the calibration is the proper fix, so try it first.
