DX6i Flaperons
#3
roger5005
I think this is the same but its in writing!
You obviously have to have each aileron on a separate channels (Ail ch2 and Flap ch6)
Under the Flaps menu set Land Flap to down 30% and Land Ele to down 10% (you will have to determine the best %ages by flight testing)
Mix1 Aile to Flap and SW to Flap.
Under WINGTAILMIX activate DUALAILE
Reverse the direction of ch6.
It works on my DX6i.
Last make sure the actual surfaces on the plane all move correctly before you fly!
Pappy
roger5005
Thank you, worked out great!
r2wjax
Using an Orange Rx receiver and Spektrum DX6i :
I plugged one aileron servo lead into "AILE" and the other one into "AUX1"
Set WINGTAILMIX to DUALAILE
Flaps to
Flap Elev
Norm 0 0
Land <up> 55 <down> 15
Mix 1
Flap -> Flap ACT
Rate D + 75% Rate U +75%
Switch MIX Trim ACT
And reversed nothing...
This works in three settings:
1 - Flaps = 0 Mix = 0 Normal
2 - Flaps = 1 Mix = 0 Flaps @ 55 % ( down ) Elevator @ 15% ( up )
3 - Flaps = 1 Mix =1 Flaps @ 75% ( down ) Elevator @ 15% ( up )
And this seems to work for me... if you equate to "AILE" to "Ail ch2" and "AUX1" to "Flap ch6"
Then it is pretty much the same idea. The position of the servos makes a difference, or at least
the side of the control used... if you need to "Reverse" anything... I did need to reverse the elevator,
but that is aside from this issue.
I hope this helps?
Didn't do a video... ain't got the time or inclination!
