dx6i mixing question
jsteele
I recently tried to mix me throttle with my elevator with my spectrum dx6i (the old one) on my GWS slow stick so it would not pitch up so much when I punch the throttle. I got the mix to work but my throws were so minimized that it is unflyable, if anybody could help me out I would really appreciate it, thanks.
The Hangar
Fly harder!
I had a similar problem with my dx6i when I tried to do elevons... My solution? Use my dx6e! I’m not sure why it minimizes the throws so much, but I hope you are able to figure something out!
DamoRC
Are your elevator Dual Rates set to different levels depending on the switch position? You are using the ELE D/R switch to turn on the mix so you need to make sure that when you throw the switch the elevator rates don't change.
EDIT: Just tried your mix on one of my models and it worked fine, didn't lose any throw on the elevator because I have the rates set at 100% regardless of the switch position. Might be simpler to assign the mix to a different switch (like the gear switch).
jsteele
Ya that was actually my problem is that is was not on the gear switch but once i did that it worked fine.
