I hope this is the right area.
My recent plane wasn't unique enough and the wing loading wasn't high enough, that's a joke, so I decided to add two more servos.
The idea was to run flaperons and elevons which Google said the F-22 uses. I found a few old posts scattered over the web, none seem to work so I started from scratch.
The problem is: If I get the elevons to work properly as elevators one will not work as an elevon.
The same with the flaperons, If I get them to work as flaps one does not work as an aileron.
If I the elevon working as an elevon it will not work as an elevator and the same with the flaperon.
I've swapped wires, reversed channels and changed the mixing. I'm fried.
here's the current, nonworking, mix:
I even tried changing the order in case it followed some type of priority that wasn't mentioned in the manual.
Ideas? Please!
- Right Elevon: Elevator
- Right Aileron: Aux 1 (Flap)
- Left Elevon: Gear
- Left Aileron: Aileron
- Mix 1: Gear > Gear, Rate -100%/-100% (to inhibit the switch)
- Mix 2: Aileron > Gear, Rate: +100%/+100%
- Mix 3: Aileron > Elevator, Rate: +100%/+100%
- Mix 4: Aileron > Flap, Rate -100%/-100%
- Mix 5: Flap > Aileron, Rate: +100%/+100%
- Mix 6: Elevator > Gear, Rate -100%/-100%
Ideas? Please!
