I'm hardly new to RC and flitetest as I've been a fan and scratch built for the past two years but I've run into an issue that's boggled my brain: my previous tx-rx combo has been compromised due to a neck strap failure but I have a DXe tx and ar610 rx. I've used the tx in the past for a BNF umx radian but I've never used the included receiver for my scratch builds. The problem is not in binding (the rx does give off a solid light after following the binding sequence) but somehow no power is going to the motor and I'm not hearing any of the sounds the emaxx 1806 used to make when I used my old tx-rx combo. After binding, I unplugged the bind plug from the rx and unplugged the battery from the esc (blheli 12a) then turned off the DXe. Next, I put the throttle stick to full throttle, turned on the DXe, then plugged in the battery so the esc would calibrate the throttle endpoints once I put the throttle stick back down to 0%. I'm a little lost because my motor is getting no power despite my 2-cell being charged up to 7.75 volts. Any advice for troubleshooting?
