E-flite Beast 3D with AS3X
fliteadmin
Administrator
Admin
In this episode of Flite Test, Josh and Josh fly a Beast! Although this beast may be very small, it has a lot of bang for the buck! Watch this episode to see all that this little Beast has to offer!
FlyingMonkey
Stuck in Sunny FL
Admin
#6
They repeatedly said this was not an indoor plane. I think though, if you had an indoor soccer field, instead of just a basketball court, you might get away with that.
Klonas
#8
05:55 Chad's expression .... LOL
But reat video guys I really liked this plane because I've never seen a plane fly so smooth in this scale and it also seemed there was quite a lot of wind.
SunShine
not crazy, just stupid
#13
hehe, grate video! are you guys planing on reviewing the geebee(maybe with a race :) )?
also, is it possible to turn down/off the gyros?
-A
Dallin
#17
Great Video! Josh S. is really getting good.. and fast.
SunShine: If you did not find your answer already, you can NOT turn the gyros on the AS3X micros down or off.
UndCon: From what I have read and heard, the boards in these new planes cannot really be used with other airframes. As I understood it, the gyros and their programming are set up specifically for the airframe (weight, wingspan, control surfaces, wing loading, etc...) that they are put in, so maybe if you had a similar airframe that you wanted to use it with it would work, but otherwise, I believe that Horizon is recommending that you do not use them in different aircraft.
-Dallin
colorex
Rotor Riot!
Good episode! I like how you compared the old and new version of the plane, to make a noticeable contrast.
As Dallin says, Josh S. is really getting better! Congrats, Josh S!
Horizon Hobby should be proud of your show!
#20
-Dallin
That's too bad the rate/gain cant be adjusted... But it's amazing that they can create a whole new board just for one plane- and so cheaply!
Great review flitetest! It was cool to see Josh S get more stick time :applause:
