Great Video! Josh S. is really getting good.. and fast.
SunShine: If you did not find your answer already, you can NOT turn the gyros on the AS3X micros down or off.
UndCon: From what I have read and heard, the boards in these new planes cannot really be used with other airframes. As I understood it, the gyros and their programming are set up specifically for the airframe (weight, wingspan, control surfaces, wing loading, etc...) that they are put in, so maybe if you had a similar airframe that you wanted to use it with it would work, but otherwise, I believe that Horizon is recommending that you do not use them in different aircraft.
-Dallin
