Not much to see, but I've applied the first layers of fiberglass cloth to the cowling form. I sealed the foam with two coats of Minwax Polycrylic and sanded with 500 grit paper. I spread a thin layer of vaseline over the form as a release agent. I'll have to wait and see how that works out.
I applied about 4 layers of glass, alternating the warp and weft threads by about 45 degrees with each application. I was hoping to do this in a single shot, but its starting to bunch up, so I'm going to let this dry, sand and put on another couple of layers. I'm using Minwax polycrylic as the resin. I had success with it when I glassed my fpv wing (
http://forum.flitetest.com/showthread.php?2368-fpv-flying-wing-build-log&highlight=fpv+wing), but I'm not sure how rigid it will be once cured. I may have to end up investing in epoxy resin ($$$).
