"Ebay Special" Knockoff 250 frame and Emax Quad Kit
Stradawhovious
"That guy"
also if you mount the cc3d using the nylon stand offs, get some M3 rubber 0-rings from Ace hardware for .10 a piece i think i paid for 8 of them.. i was originally gonna go that rout before going to double sided tape.
chris.
I removed mine from that useless plastic houseing, and mounted it with screws, nylock nuts and a 1/2" piece of dense foam cut to fit. Stays level, but the foam under the board offers enough vibration resistance to seemingly keep the bird pretty rock solid.
jipp
i used the included nylon stand off hardware to mount the PDB to the bottom plate. i think ill will order up a case of all different size m3 nylon stand for future use since i will try to source my next project i think. i do have 4 m3 stands off i did not use. but no nylon nuts for them.
i did end up buying 1 of these for 1.50 shipped.
http://www.ebay.com/itm/Mini-Size-A...965?pt=LH_DefaultDomain_0&hash=item3f4ad27065 i will use it for this prpject or the next one.. figure for 1.50 worth a try.
chris.
