Longbaorder23
Hey all,
I live in a place with very unpredictable weather, and it fluctuates plenty. Although when it rains, its very light with no wind. Can i fly my edf fpv jet in this weather? I plan eventually on using that fuel wrap, and coating my plane to preserve the foam in the harsh conditions i live in, and just for light protection and easy cleaning if i land in muddy grass or something. so Id seal up the entire plane and make it so I dont have to take out very much (if an) hardware to use the plane. And while im flying i will temporarily seal up the exposed battery compartment and all electronics. The only piece of electronics that will be exposed to water is the brushless motor. I will take special car to keep it clean and rust/corrosion free. Does this seem workable? I dedicate lots of time to this, and will not skimp out on work if needed! Also i will probably use some sort of spray or chemical to seal up the cracks in between the fuel sheets, so it will when flying be 100% sealed. Feedback? Thanks!
