[QUOTE="Bricks, post: 430638, member: 17241" As you can see the difference between 4S and 3S is huge in real life even thou the 12X6.5 prop puts out more Watts the 11X5.5 is way better at 3D as it lets the motor spool up quicker for 3D throttle response
These are my bench tests[/QUOTE]
Thanks
@Bricks
I ran the 4S test on the NTM2826 1200kV last night. The motor is only rated for 17A so once I saw the first result for the 8x4.5 prop on 4S I decided not to try larger ones. Did a 2S, 3S, 4S series to show the difference in RPM and power.
So this weekend I think I will try to compare flying with the 10x4.7 on 3S and the 8x4.5 on 4S just to see if I can feel the difference that the extra 250-ish grams gives albeit knowing that this is pushing this motor too hard.
DamoRC
