Here is everything you get with the Electrohub Quadcopter Kit, but don't just stop at quads! Tri, Hex, Octo, it's all possible with the new hub.
If you're looking for just the power distribution plates, click here.
RTF Quads offers an ElectroHub Electronics Kit that you can customize with everything you need.
The flight control board is already preflashed so no need to fuss with expos. It's basiclly plug and play! The packaging also clearly labels everything including the proper motor rotations.
Today we are going to be setting up the Spider Quad (aka Dead Cat) configuration. This is a good setup for mounting cameras and keeping the booms out of the shot.
We recommend that if you are also building the Spider configuration to add the Camera/Battery Mount. This helps to balance out the quad much better. If you are building a basic X or Plus configuration, the mount is not necessary.
Whatever configuration you end up building, we hope you have as much fun with this kit as we do!
LINKS
What's your favorite type of multirotor to build?
