Captain
Hey Guys,
I'm new to the forum and need a we bit of advice.
I'm in process of building an Octo-copter with the Electrohub booms and plates, though I have no idea on how I'm going to go about soldering/connecting all the components together and what battery(s) I'm going to require.
Run down of the kit I'm going to be using:
Props:- Unsure on what prop size/ratio, Help appreciated!
Motor:- 8 x RTF Mini Motor X2204 2300KV
ESC:- 8 x F-30A-HV Fire Red series High voltage (2-6 Cells) OPTO SimonK-(RapidESC)
FC:- 1 x DJI Naza M V2
RX:- 1 x OrangeRx R620 Spektrum/JR DSM2 Compatible Full Range 6Ch 2.4Ghz Receiver w/Failsafe
1 x OrangeRx R100 Spektrum/JR DSM2 Compatible Satellite Receiver
TX:- 1 x OrangeRx T-SIX 2.4GHz DSM2 6CH Programmable Transmitter w/ 3-Position Switch
On inspection of the electro hub plates, I see there are only 8 large +/- soldering points, I'm not sure if I should get another set of plates and have 4 escs on each plate.. Also battery choice wise I'm wanting to get the longest possible flight time with this setup.
Majorly baffled here and any help would be great!
