Hello FliteTest members,
Christmas coming up i thought i was a great time to upgrade from my LaTraxx Alias to a self built quad.
I have been looking at parts and have some questions i would like answered so that i don't need to reorder parts that i have forgotten or that are bad.
Here is the list i have so far:
Transmitter: Spektrum DX6i
http://www.spektrumrc.com/Products/Default.aspx?ProdId=SPM6630
ESC: Afro 20amp
http://www.hobbyking.com/hobbyking/..._Motor_Speed_Controller_SimonK_Firmware_.html
Flight Controller: Naze32
http://abusemark.com/store/index.php?main_page=product_info&cPath=1&products_id=30
Servo Leads:
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=21758&aff=61689
Props: 9x4.7E CF
http://www.hobbyking.com/hobbyking/...ation_with_DJI_Fitting_1_pair_EU_EU_Ware.html
Battery: 4s 3000mah
http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=8852&aff=61689
Motor: T2212-980KV RTF Motor
http://witespyquad.gostorego.com/t2212-980kv-rtf-motor.html
Now my concern are the flight controller and motors. Do you guys recommend the KK2.1.5 or the naze32 and why? And for the motors together with the props and the 4s they should each pull 1kg of thrust. I plan on adding a mobius, board camera and fpv gear in the future. Do these parts look good or should i pick others?
Also would using a break out cable instead of the electrohub system for the wiring be easier? the esc have bullets pre soldered making it easy? i can solder quite well so thats not an issue.
Thanks in advance!
EDIT: changed the flight controller from kk2.1.5 to naze32
ESC: Afro 20amp
Servo Leads:
Props: 9x4.7E CF
Battery: 4s 3000mah
Thanks in advance!
