baronbernie
Got up early to clean up my work table (haha never happened) to make room to work on my FT Delta. The build was simple and went together without any problems. After centering the servos and adding the linkage stoppers, the pushrods slipped into place. Got out my Orange RX transmitter, went and changed the setting for elevon mixing and attempted to check the elevon setting by watching the plane as I went through the motions. The motor came to life with no problems but the settings were reversed.
I watched the videos on elevon settings a few times and went back to the plane. Turned on the transmitter, pluged the battery in and yep the same problem. Switched the servo connectors and can you believe it, the same thing was happening. Pushing the stick back and forth gave me a left, right reaction, and pushing the stick right and left gave me an up, down reaction. Ughhhhh!!! Went back to the owners manual reread it, looked at the plane and everything was hooked up as per instructions.
The only other possible setting to change is reversing the elevon setting. For over 15 minutes I went through just about every possble area that could be switched. Sadly the plane sits on the work bench in the same condition it started out with.
If anyones knows this situations first hand, and can suggest a helping set of directions, please do so and thank you.
