Help! Emax Femto Burn Up/Ideas for Micro Fc with Pdb
I have an Ft gremlin, and recently the flight controller stopped working. This is the second time that this happened and I am tired of working with these boards. Does anyone know of any other 20mmx20mm ish size flight controllers with an integrated pdb?
Mad_Mechanic
To be clear, when you say 20mm x 20mm ish, are you referring to the mounting hole pattern or the physical size of the PCB?
Mad_Mechanic
Ok, I started looking around online and when I was searching 20x20mm boards, many have a standardized 20x20mm mounting hole pattern but the board is bigger so I didn't want to go suggesting a board that didn't fit.
Does anyone know anything about the new flitetest full speed rc flight controller and 4 in 1 esc stack? It is the new fc and esc from the ft gremlin v2. I haven’t found much informaction on it since it was just added to the store on the 19th.
