tribal_fpv
I think I flew them once
Haha saw this after I replied about your motors I’m worried that if it’s not the motors it’s the ESC’s any help you be greatly appreciated and if I can share anything I have I gladly would!!!!
Thanks again!!
Hey. I've been having trouble with my quad flipping when I increase the throttle. Like it'll hover but when I increase the throttle past hover it flips or roles gradually in a random direction.
So. I think it's the ESCs. I'm running cheap simonk ESCs that came with my quad. If your ESCs are already gone or you're holding them for someone else I completely understand.
Thank you so much for your generosity toward your fellow enthusiasts.
BTW. What parts do you need? I have a cc3d FC if you need it?
Thanks for your reply. Yeah. I've checked all those things. LOL, multiple times. And tuning the PIDs doesn't fix it either, unfortunately.
The weird part is it will hover well and I can kinda flight it but when I increase the throttle it gradually roles to one side then when I decrease the throttle it roles back to level (and the harder I increase the throttle the faster and harder it roles), so I know the FC is oriented correctly and that everything is connected correctly.
I even upgraded my FC from a cc3d to a spracing f3 running betaflight. Still didn't help.
I talked with some guys on UAVFuture's discord chat and they said it sounded like the ECSs were out of sink with each other but unfortunately my ESCs aren't programmable. I tried connecting them to blheli configurator but they wouldn't connect. That's why I'm thinking it's the ESCs.
What are your thoughts?
Thanks again for the help.
Still want them?
Thanks for the advice. But I've already tried doing an ESC calibration to no avail. And unfortunately, I'm running cheap ESCs that use PWM instead of oneshot or Dshot.
Any other ideas/suggestions would be much appreciated.
Thanks again.
I've tried that too. Thanks for the suggestion though.
Unfortunately, I bought the drone as a PNP so the ESCs came with it. And I can't find the drone anymore so I don't know where to find ESC specs.
The drone is made by Arris and the box says FPV250 but none of the FPV250s on google look like mine.
I found out it was my esc that had gone bad sorry I’m a little late But if you still have them I would gladly take them thank you
ECS's are gone! Sorry for the late update.
