Colfadrafret
I've finished my Storch scratch build, and have set up controls on my Spektrum DX6i transmitter and old 6 ch .Spektrum receiver. All the surfaces work and are centered. I went for the flaps option with two servos ( facing same way) on a Y lead.
I have read countless contradicting tutorials on setting up flaps through the GEAR channel using the DX6I GEAR switch , but no luck. No movement at all after enabling gear switch in a mix,setting U and D to positive and negative amounts.Also tried reversing . Nothing works!
I have also tried the same using the FLAPS switch with no results; and note that the monitor view shows movement on the AUX channel that aren't visible on the Storch.
The only issue I have noticed is that when i first connect to the Rx, the rudder oscillates violently before it settles down, then is fine. The other issue is that one flap servo buzzes all the time. It's a brand new servo.
Can anyone with my Spektrum setup help ? ?
