RC Lawn Chair Pilots
https://anchor.fm/rc-lawn-chair-pilots/episodes/Episode-5-Friends--Flying--and-Fixing-ehvmk8
It's all fun and games till you hit your friend in the eye. That, and so much more on this week's episode of the RLCLP Podcast!
See below for links to everything we've talked about this episode.
DJI Robomaster EP Core
https://www.rcgroups.com/forums/showthread.php?3675673-DJI-RoboMaster-EP-Core-STEM
Archer GR6:
https://www.horusrc.com/en/frsky-2-4ghz-access-archer-gr6-receiver.html?acc=22415
ServoCity Hitec OEM Replacement Gear set for the HS-40 Economy Nano
https://www.servocity.com/55367-hitec-oem-replacement-gear-set/ ELF DLG http://www.kennedycomposites.com/elf.htm
Events:
Horizon Hobby RC Fest, OCTOBER 2 - 3 | ELI FIELD | MONTICELLO, IL
https://www.horizonhobby.com/rc-fest.html
Coming August 9-13: the MultiGP Virtual Open
https://www.multigp.com/coming-august-9-13-the-multigp-virtual-open/
RealFlight and RCG Virtual Flyin
https://www.rcgroups.com/forums/sho...ht-and-RCG-Team-Up-for-the-Online-VirtualFly!
Soar Utah Event
https://www.rcgroups.com/forums/sho...Utah-2020-September-3rd-through-September-7th
St George Electric Festival
https://www.rcgroups.com/forums/showthread.php?3516441-St-George-Electric-Festival-2020-Sept-25-26
NEAT 2020
https://www.rcgroups.com/forums/showthread.php?3592709-NEAT-2020-Sept-17-20-Downsville-NY
BEST 2020
https://www.rcgroups.com/forums/sho...Best-Electrics-in-South-Texas)-Date-Field-TBD
SMALL 2020
PRODUCTS WE USE (affiliate links)
TARANIS X9D PLUS 2019 SE
https://www.horusrc.com/en/x9dp-se-2019.html?acc=22415
TARANIS QX7S
https://www.horusrc.com/en/frsky-2-4ghz-taranis-q-x7s-access-transmitter.html?acc=22415
RX6R RECEIVER
https://www.horusrc.com/en/frsky-rx6r-receiver-6-16-channels.html?acc=22415
RX4R RECEIVER https://www.horusrc.com/en/frsky-rx4r-receiver-4-16-channels.html?acc=22415 RECEIVERS https://www.ho
rusrc.com/en/receivers/x-series?acc=22415
TRANSMITTERS
https://www.horusrc.com/en/transmitters?acc=22415 2S 300mah
BATTERY (Derek’s Glider)
https://hobbyking.com/en_us/turnigy...ffiliate_code=WDFVYXWOLBIOSQV&_asc=4162782245
LIPO VOLTAGE CHECKER
https://hobbyking.com/en_us/hobbyki...ffiliate_code=WDFVYXWOLBIOSQV&_asc=5130215602 3S 500mah
BATTERY
https://hobbyking.com/en_us/turnigy...ffiliate_code=WDFVYXWOLBIOSQV&_asc=7309074393
Archer GR6:
Events:
Soar Utah Event
NEAT 2020
BEST 2020
SMALL 2020
TARANIS QX7S
RX6R RECEIVER
TRANSMITTERS
BATTERY
