Epp fpv
fliteadmin
Administrator
Admin
Designed specifically for FPV flying, the Hobby King EPP FPV Plane is great platform to get your camera gear in the air. This large plane is durable, stable and can carry a lot of weight!
bicyclemonkey
Flying Derp
I was looking at this video b/c I have the 900MHz 200mW FPV system just like this one from HK. I noticed the antenna on the VTx on the plane is not the one included with the HK system. Which antenna did you use and did it give you better range, image quality etc.?
FlyingMonkey
Stuck in Sunny FL
Admin
#4
The vTX antenna looks like the same antenna I got with my stock system. They did say they were using a patch antenna for the ground system. Although, it looks like numbers for numbers, the home made antennas that David builds are just as good, if not better than many of the commercially available options.
I am pretty sure David has directions for building your own FPV antennas on his website, http://rcexplorer.se/
