Oh yeah I am definitely going to make one of those suction things once I get to full size. I had also seen your slip on flywheel concept and I would be all in on that, but I don't want to cut the shaft off this motor, it really is only standing in since I didn't want to buy anything. That changed today when I bought a IFLYRC F2212 920KV motor to replace this one off my motor glider. It has a tiny little shaft so I won't even have to cut it off and it will make the nozzle arm 10mm shorter at least.
Another day another design though. I was not happy with the ~11.2mm stroke which also meant I had a pretty big left-to-right movement in the needle on every stroke. My bearing was already pressed right up against the motor shaft so it couldn't get any smaller. To get around this I decided to place the bearing on top of the motor shaft with the screw inside, so add ~6mm of distance on top of the motor. That way I can target any stroke depth of 6mm or more. It was easier to do just throw this together with a traditional cylinder flywheel shape.
6mm stroke seemed nice while cutting it close to the minimum amount of stroke to cut DTFB / MakerFoam, but the motor shaft grub screw was too heavy for it to balance properly. I had to drop to a nylon screw with a few washers on it to get close, so I increased the stroke depth to 7mm and it is much closer now. It probably could go to 7.5mm and then be adjusted with a washer for weight, but this works pretty well. You can see the two ponies cut-- the dark one is with the old flywheel and the light is with the new one, same needle. The kerf (tearout?) is much less with a lower stroke. The difference is also noticeable on the nozzle.
After running 20 minutes and cutting a pony, the cut was actually registering in the same ballpark of temperature as the nozzle. Super cool and not even PLA troublesome. The bearing ends up a little hotter for some reason in this, but it is actually another bearing from the same broken motor so it may be damaged slightly? In any case it is fine temperature-wise still. The base of the motor is the hottest part at 50C, so maybe some tiny fins could be added to the design to add a little airflow to the motor.
I also found some 22ga nichrome wire (0.025" / 0.635mm) in one of my drawers and it works acceptably too. That's what's in the first photo. I definitely want to use the stiffer music wire, but I don't have that size on hand, and it is nice to see that nichrome can work in a pinch.
I think I'm zeroing in on the last bits of the design. I just need to integrate some wire management into the carriage, but I will wait until I have the 20mm extrusion to see where the wires lay.
