ERC TimSav - Cheap DIY CNC Foamboard Cutter
Flying Farm Kid
I really like the animations fusion 360 lets you do. To me it's way clearer than pictures and instructions.
For the 2nd y axis did you just use a splitter cable to route in the 2nd motor?
And in lazerweb is it possible to only generate the gcode once or do you have to do it the old way because right now I use a tool that does it all at once.
Mr NCT
VP of SPAM killing
The CNC shield has one red socket that can be slaved to move with the Y axis by putting in jumpers on the board. Laserweb lets you select different layers or colors and have different speeds and cut depths then process to gcode all at once.
AIRFORGE
Make It Fly!
Does anyone have a way of contacting Ben Harbor I want to erc his Stearman but you cant process the files that are posted does anyone have the files or a way of having him publish them? thanks
The plans are a raster image intended for printing only. (IP protection)
If you want to cnc the plans you'll need to trace them manually with vector software.
I use lightburn. There are several options available to use the raster images which may require some manual work, but work very well.
Mr NCT
VP of SPAM killing
Here's the web site that explains configuring the 4th axis as a clone of the Y.
Edwardchew
Hi everyone!
Waw I'm amazed that this thread is still so lively!
Sorry about the screw type/size as I'm used to the metric system here
The shim and bearing were from here when I develop this. So you guys can conveniently get them here. It's always in stock.
Metric screws - you guys can source it from aliexpress
Hope I can make it to Flite Fest again next month if i could gather enough fund in time 😁
Cheers!
Flying Farm Kid
A few hours printing, now I just have to convince my parents to let me buy the rest of the parts to upgrade it lol.
Flying Farm Kid
With the ERC added I'd run out of room in the shop to paint inside. Never one to leave well enough alone I built a vacuum table for the ERC and lid big enough to cover everything then mounted an exhaust fan and filter in the exterior wall. Best of both worlds!
View attachment 244219 View attachment 244220 View attachment 244221
Could you take a photo of your cutter head, I am finally starting to assemble mine and I don't know what tooth the servo gear goes on. thanks!
Mr NCT
VP of SPAM killing
I modified the gear a little to allow for more travel - not really necessary :D
Here's how it mounts - top tooth on the gear engages in the top slot of the rack.
Flying Farm Kid
Thanks I got mine figured out, I am slowly starting the reassembly, the guy that I bought it from got a tap stuck in the 20x 40 extrusion so I have to get that out to make it nice but I a making progress, I am hopping to get it finished before I go back to school in a week. And for the dual stepper it is just soldered into the same wire as the other y stepper, thanks
Flying Farm Kid
Have you had issues with your cutter head bending mine makes beautiful cuts diagonal and in 2 directions but in the other 2 it bends abck and forth. Also what flywheel is that I cannot find the file again. Thanks!
Foamforce
Here you go - this is a completely different design so might not be worth doing if you already have one built, but this is an incredible design. I built one and it is dang near perfect. Link to OnShape design in the video.
With the Z axis stepper instead of the servo, does this allow you to use standard GRBL firmware if you wanted?
