I agree with Dudley1001
Also, make sure your home switch, rollers, and whatever the switch touches are not loose. Loose parts can cause inconsistant homing. I recently readjusted the rollers on one of my 3D printers because there was just enough slop to cause unwanted movement i the nozzle and print bed.
Check also for a home all axis GCODE like G28. That should really only be needed at the start of a print if at all. I have Lightburn set up to NOT home at the start, but rather start wherever the head is. If I ever build a better bed with alignment marks or rails, I may change to using homing.
