Dudley1001
Oh don't go chasing that idea, next it will be 2 y rails, then stronger rails, z step motor, then linear rails and of course a bigger badass controller board and FluidNC! Ok I have to admit that the controller board and Fluidnc are on my timsav as is a 10w laser so who am I to tell you what to do but if you do, I have some optical distance sensors sitting here, the software to run it, that is all on youWhat a GREAT idea! It could compensate for the waviness of the foam board. Maybe I could hook up an autoloader/unloader to it, too!
BTW there is a new software out there for grbl based lasers called Beam Bench which is a free software much like Lightburn. Looks like it may work for the timsave but probably would require GRBL1.1h-servo to work with our setup. Just got it last night so I will report back after some tests. Beam Bench
