Scooter The White Rabbit
Checked into a 1940's two seat plane called the Ercoupe. The designer connected the cable controls for the rudders and the ailerons together so the "Wheel" controlled both when turned left or right. No rudder pedals. Can this be done by rigging Y-cable servo harnesses between the aileron and rudder servos plugged into the aileron channel on the receiver?
And since the Ercoupe was a twin tail, could I use 2 servos since my rudders are quite big, linking them together instead of 1 servo with a single long servo wire? Or would it be better to run a next size up (5 gram to a 9 gram) single servo and the long wire?
