I have a cheap chinese 30a esc, I have been looking around the internet for 2 hours and i have not found a fix. It has been recently in the rain, dried it, worked perfectly fine then 30 mins later it just decides to not work. Not a voltage issue, 12 volts exactly, Not a throttle error or something because when i go full power it goes into a ''special'' thing im not sure of like 6 musical tones then beeps like morse code and i dont understand anything!! (that tells me it can read the full power signal) Anyways, It goes 1-2-3, proceeds to beep 10 times then 1 long beeeep and then the motor does not spin AT ALL! Please help i have been searching 2 hours all over the internet and i dont know whats happening! And if your nice maybe you could help me a bit understand the musical tones
After the musical tone at full power, if i keep it there it goes beep then beep beep and so on and so fourth, Then some other patterns that im not sure of.. I only care abt the esc working and not programming it or anything, What could i possibly do? Its been 5 hours since the rain and not 100% OF THE ENTIRE MOISTURE Has been evaporated so could that be the case?! I dont know, Please help! I'm new!
(note! Before this issue happened, when i was outside just about to take it in while it was still raining, when i wanted to start from 0, it was like brbrbrbr and going super low rpm maybe trying to sync somehow? And then home i lifted the car in the air and same issue happened! Even more.. But when i dried it, KINDA turned back to normal? I would be really sad if i fried the esc somehow as i dont have much money)
