Solved Esc error code and motor not working
Okay, so try setting the tester to 100%, plug it in, wait for the beeps and then turn it down to 0% let it do the confirmation beep and see if it works then...
So if that doesn't do it, you can try opening it up and look for any spots that have green or white corrosion and clean that off with some isopropyl alcohol, then let it dry over night in some rice..
mestyr
YOU WONT BELIEVE THIS. OH MY GOD. I opened the esc right?! I did 99% iso alchohol yeah On the esc just scrubbed it a bit, AND NOW IT FRIGGIN WORKS LETS GO. Holy im so happy right now, GONNA DRIVE THE CAR THROUGH THE ENTIRE HOUSE 10 HOURS WOOOOOOOOOO
Yay! Glad its working! (y)
mestyr
Dude thank you again! Nothing was burned, just a bit bit of moisture or something else, Thank you for ur implication once again! Time to drive ! WOOO im so happy thank you Houndpup Rc! :D
Shurik-1960
You have opened the regulator, washed and dried it, it is excellent. Dip it 2 times with drying in Plastik 71 varnish. Your regulator will stop being afraid of water.
