I highly recommend a wattmeter as well. It will save you from burning any more ESCs as well as everything else. Without a wattmeter a good test is the heat test. If anything is running very hot to the touch after a good quick run (and I do mean quick run) then you need to change something...different battery, lower prop, larger ESC, etc. But really, I'd pick up a wattmeter.
