TechGeezer
I built an FT explorer using the standard comonents and C power pack, FrSky X8R receiver, Eagle Tree Vector comtroller using the SBUS connection between X8R and Vector. Also the RSSI connection between X8R and Vector. All seemed relatively normal in bench testing. Next I wanted to display Vector telemetry on the Taranis transmitter and followed instruction on the internet for connection between UART port on the Vector and Smartbus port on the X8R. Powered up the system, (Titan 4S lithium ion) and all seemed normal until I touched the throttle control...observed a couple of twitches of control surfaces and then noticed smoke coming from the motor and ESC. In trouble shooting I found that one leads from ESC to motor had melted the solder joint and came lose.
Next I replaced the ESC with a new BLHeli 30A unit but left the motor disconnected. Powered up the system again ... Another ESC meltdown and again one of the motor leads melted the solder joint on the ESC board. How do you smoke and ESC with no motor connected.
Speculated that somehow the telemetry connection from UART to Smartbus was the culprit. Removed the telemetry cable, replaced the ESC, reconfigured the Vector from factory defaults, etc.. Still had the RSSI connection between receiver and Vector. Testing seemed normal again, control surfaces responded as expected, motor responded to throttle as expected... But still 1 issue with RSSI values reported by the Vector not matching the Taranis, but thats a different discussion. I tried one last change, Rebound the X8R receiver to the transmitter in Mode 2 (no telemetry) instead of mode 5. Plugged in a 4S battery but only got 2 beeps instead of the expected 4. Tried again with same results, Swapped to a 3S battery, a couple of beeps then smoke from the ESC and motor, both overheated.
I searched the internet for similar problems, but no luck. Any theories why the ESC's are getting smoked? Any suggestions appreciated.
