Hi all i need a little help got my 1st race quad for xmas i got the Eachine Wizard from banggood =/Thay messed up and did not send me props and bind plug. After getting a plug of a m8 I find that one motor is not working. So they are now sending me a new esc and the props the only thing is there sending me a different esc to what is on the quad. So what i need to no is will this esc work with the other ones that are already on there or do i need 4 the same.
the esc on the quad are Eachine 20A BLHELI_S ESC
Item name : 20A BLHELI_S ESC
Con.Current : 20A
Peak Current(10s) : 25A
Input Voltage : 2-4S
BEC : No
Programming : YES
Firmware : Blheli_S
Weight :7.9g
Size(PCB) : 27*12mm
the one they are sending is Racerstar RS20A 20A BLHELI_S
Specification: ( Test Table)
Brand Name: Racerstar
Item Name: 20A BLHELI_S ESC Electronic Speed Controller
Model: RS20A
Con.Current:20A
Peak Current(10s):25A
Input Voltage: 2-4S
BEC: No
Programming : YES
Firmware: Blheli_S
Weight:7.9g
Size(PCB):27*12mm
thanks for any help
Con.Current : 20A
BEC : No
Programming : YES
Firmware : Blheli_S
Weight :7.9g
Size(PCB) : 27*12mm
Model: RS20A
Con.Current:20A
Input Voltage: 2-4S
BEC: No
Programming : YES
Firmware: Blheli_S
Weight:7.9g
Size(PCB):27*12mm
thanks for any help
