JamesWhom
Project Air on YouTube
As long as I have been flying and building RC planes, which isn't too long, I have always wanted to put a camera into the sky. Up until now I've been focusing on smaller projects, but now I think is the time, the time to go all out... and build an 80" wingspan beast of an aircraft.
My design is based on Ed from Experimental Airlines' OZONE plane, although this one I want to call the 'DEFENDER', because its intended to be the flying equivalent of a Land Rover, square, tough, and dependable. It is meant to be a 'proper' plane, not a model of one, but an actual aircraft.
The construction techniques are not the same in the main fuselage, although the booms will likely be the rounded box shape that Ed shows how to make in his excellent videos.
Here is the OZONE video.
And here's how far I've gotten with my build.
The fuselage will contain the camera and batteries. It may contain the radio gear too.
The wing is 80" long, the chord is 7" wide with a 2" control surface. The control surface from the middle section will be removed.
It splits into separate sections
The motor is a Turnegy 1100kv at 300 watts. Hopefully it will be powerful enough. I think it was something like 1200g of thrust with a 10/6 prop. Maybe I should have gone with something bigger?
The mount is reinforced with lots of hot glue and is mostly a plywood former.
Let me know what you think!
