telnar1236
EDFs are cool but compared to prop designs they are inefficient and lack thrust. Beyond that, as a whole, the performance of small RC planes has not significantly improved since the switch to lipo batteries and brushless power. Top speeds are still around 120-130 mph unless you want to buy something quite expensive or build a difficult to fly custom design, and flight times have only really gone up from 3 to about 4 minutes on EDFs for most designs and have stayed around 5-10 minutes for most prop planes.
The goal of this thread isn't necessarily to build a plane, but more to experiment with different ideas that might help make better speeds and flight times possible. That said, I still do plan to build a couple planes. Specifically, I have 3 designs I'm thinking of, one which will experiment with increasing speed, one which will experiment with increasing EDF flight times, and one which will try to combine both.
First is the plane I'm currently in the process of working on which is meant to play around with high speeds. It's a pretty conventional pylon racer design, but it's 3D printed and designed to be relatively inexpensive to build. It should also have a reasonable landing speed and easier takeoff performance hopefully than most pylon planes with a power off stall speed of only about 30 mph. Predicting top speed is hard at the best of times, and I don't really know how the power system will be behave, so I'm throwing at a dartboard when I say the top speed should be somewhere around 150 mph.
It's primarily intended to test a laminar flow airfoil I designed for the third plane in this project in a simpler design that I'm less worried about crashing. It uses a 1900 kv motor and a 6x6 prop on 6s.
Next is a design that should increase EDF flight times. I'm mostly building it because I want to experiment with a boundary layer ingesting EDF similar to what I was planning on my original speed plane design, but hopefully in a more forgiving airframe.
This is meant to use a 64mm EDF on 4s with a 4000 mAh battery.
And finally is the plane meant to combine it all into one package. The goal is an EDF with a top speed exceeding 130 mph and capable of flight times over 7 minutes, and hopefully 10 minutes, while still maintaining a 1:1 TWR and that still handles well and is fun to fly. This design will likely change based on the results of testing the first two designs as well as due to any changes in my thinking.
Currently it is designed to use twin 50mm EDFs on 4s, and I would prefer to keep it a 4s plane so that it stays accessible to more people, but I'm also considering an 80mm EDF on 6s. It uses the same laminar flow airfoil as the speed plane in part 1 of this project currently, which should be thick enough to hold retracts while still being efficient enough to give it that high top speed.
As a whole, I expect this project to take me at least half a year if not more, but I'll get a couple of neat designs out of it if they work.
