telnar1236
Now that I have a day behind me, I have a couple conclusions from the v2 flight. The big one is that I feel ready to start getting more into designing the 80mm version. Performance was good and it was stable, especially when at speed. Slow flight will be improved a lot by flaps, but it was fine, even if it looked terrible. Based on the control authority the stabilators gave me, I think I need to include ailerons in the big version - especially at low speeds they weren't really as effective as I would have liked and I had to set the roll deflection the same as the pitch deflection.
I also did some static testing to determine the thrust of the EDF when installed in this setup - I measured 620g which fell off to around 580g over time which suggests that this wasn't a very good installation of the 50mm EDF unit and goes a fair ways to explain why the speed wasn't as fast as I was hoping. The CFD predicted drag at a 91 mph speed was 490g which isn't all that much of a loss of thrust so I'm feeling better about how it performed.
I also printed a shorter version of the duct for the 80mm EDF to make sure the inlet wasn't overly restrictive (I was worried that was why the 50mm EDF was underperforming) and thankfully it looks like the issue is the lack of the EDF bell mouth in this setup and not the inlet size. Uninstalled, the 80mm EDF gives me 3.2 kg of thrust with a bell mouth, but only 1.6 kg of thrust without. With the duct, it was boosted back up to 2.2 kg. This isn't as high as I would have liked compared to the thrust with the bell mouth, but it is still plenty to do what I want it to. I also have some ideas about how I might be able to improve this value without increasing inlet area by changing the internal duct geometry to get more thrust out of it.
