Hi Everyone,
I was curious to know if this has happened to you. I am scratch building an Explorer from the plans that I down loaded. I taped all the sheets of paper together and glued the sheets of paper to poster board to make templates. After I traced out the pieces for the nose I did a dry assembly and found out that the nose skin part A & B is to wide to fit the nose. I know how to fix this problem but has this ever happen to you ? What do you think caused this problem ? Everything else seems to be ok. Any thoughts on what could cause this ?
Al
Al
