Killing time, started designing another one, intent is to go mostly fb but I want to then go with a one piece wing non removable so that means the fuse will have to change slightly. Started on the wing first of course
. All fb other then a cf rod spar (green) which will be housed in a FB spar (pink) and the ribs will be fb also.
Going to do the same as I did with the tail feather and sand the TE to a taper and then fold and laminate the wing together. Ailerons will be cut out after and will still do the balsa hinging.
