Extreme Squirreltail 300 Coming at you
Wildthing
Well with all the rain lately holding up jobs let's break out the foam and start a new Extreme. Spar was finished up today, now working on the wing and the other control surfaces that have to be sanded before folding.
Wildthing
All the surfaces are sanded to a taper. Wing is going together and it is a little bit of a pain because the airfoil is symmetrical so no flat side. All the other surfaces are folded and glued and aileron templates cutouts inplace just waiting on glue to cure. Ten cut them out and prep all the balsa for the hinges. The sanding to a taper does give you a nice smooth trailing edge and should be pretty aerodynamic, rudder is a good example.
Timmy
All the surfaces are sanded to a taper. Wing is going together and it is a little bit of a pain because the airfoil is symmetrical so no flat side. All the other surfaces are folded and glued and aileron templates cutouts inplace just waiting on glue to cure. Ten cut them out and prep all the balsa for the hinges. The sanding to a taper does give you a nice smooth trailing edge and should be pretty aerodynamic, rudder is a good example. View attachment 173547 View attachment 173548 View attachment 173549 View attachment 173550 View attachment 173551 View attachment 173552
That's some nice beveling action you got there
I used to do that on really small wings so I would still get an airfoil.
This used to be a small chuck glider for throwing in my living room but its tail broke off. You do a much better bevel though.
Wildthing
This used to be a small chuck glider for throwing in my living room but its tail broke off. You do a much better bevel though. View attachment 173553
The only thing possibly different is I might have cut the wedge a little wider out of the fold, I also crush that edge down so the fold isn't as thick.
Wildthing
Now to figure out where my control rods are going to run through after reconfiguring the tail feather to make a one piece elevator my normal route isn't going to work. Elevator servo is going to be mounted inside the fuse and the control rod will run straight back through the formers with no bends. Rudder will be a pull pull setup still but just routed a bit higher.
