EZ Glider to 2 channel RC
Larrypgmr1
I want to convert the EZ glider to a 2 channel for slope soaring. I have only built chuck gliders so this will be the first time to install the electronics needed. Any suggestions are very welcome. Thanks.
Innaviation
If you want to eventually make a fully working rc plane you would probably be best to get the FT power pack and just not use the motor. If you just want a glider then using a battery like this and hooking it up to a dsmx receiver with servos would work just fine. Just make sure the battery has the right kind of plug and that should work great.
Hai-Lee
Old and Bold RC PILOT
Surely the receiver to be used should be compatible with the transmitter being used. If he is using a different brand of transmitter than such a purchase would be a waste of money.
I always ask what radio equipment they have or are planning to use before making any radio related recommendations. Just a money saving courtesy!
Have fun!
