I fully understand. I've cut open at least 10 different ones so far. 2 of them were your Bronco. The BEST flying EZ plane, in my opinion!I was sad when I had to dissect my F22 to remove the electronics...
Have you made my 3-channel Mini EZ Glider yet? I actually prefer that to the beloved Bronco...I fully understand. I've cut open at least 10 different ones so far. 2 of them were your Bronco. The BEST flying EZ plane, in my opinion!
No. I have the parts cut, but have not started to build, yet.Have you made my 3-channel Mini EZ Glider yet? I actually prefer that to the beloved Bronco...
plans?Here's to hoping mine flys. Slow progress while working on a balsa build. Two tractor A pack radials with 6x3R props on smallish 3s. Maybe add gyro for first maiden? Not exactly EZ style. Never shared plans before, but I might if this goes well.
I'll do that, once I get a maiden with confirmed CG and elevons area, and tweak a few FB profiles. Still waiting on smallish ESCs to arrive. Getting anxious to throw that dart!plans?
Success! A little tweaking on the CG, and it will be done. Docile flier, nice landing flair. Heavy shipping tape under nacelles should hold up fine on belly landings. Looking forward to trying 4s. Is there a resource page for user-submitted designs to post? A few weeks and I'll post a slightly revised design.
Plans?Success! A little tweaking on the CG, and it will be done. Docile flier, nice landing flair. Heavy shipping tape under nacelles should hold up fine on belly landings. Looking forward to trying 4s. Is there a resource page for user-submitted designs to post? A few weeks and I'll post a slightly revised design.
View attachment 214315 View attachment 214316
I was pretty shocked to hear that too! I much prefer the 3-channel to the 2!While I'm here, ...I'm somewhat dismayed, after hearing that the EZ 3 channel power pack kits will no longer be available via the FT Store.
I go now to ponder the meaning of life...with no EZ 3 ch.
They meant to only sell the EZ 2 ch, but they also received some 3 ch versions. No clear explanation of how.why are they doing that?
put motors in frontHow to make it into a tractor configuration
Don’t forget to flip the propellers around to face forward again.put motors in front
Put them on the front if the wing, of course. Left is still left, right still right. But switch the props, left to right, right to left. In pusher or tractor, the "nipples" on the props always face forward, in the direction of flight.How to make it into a tractor configuration
I design these for a living...
I design these for fun...
A four motor B17! Life is good!
