EZ Piglet Maiden
RBunch4468
Maiden flight of my EZPiglet I bought at Flite Test ‘26. It will turn right just fine, but really struggles to turn left. My instinct is to increase the angle of the left rear leg. Other ideas?
Also, flights were very short. About 30 seconds before power died back enough to lose elevation. Needed to fly full power
bisco
bad battery maybe, hard to say without testing.
when you apply right rudder, does the right prop speed up?
RBunch4468
I get a motor speed change operating the aileron axis, both left and right. I am going to double check the motor alignment for parallel to ach other and to the centerline of the ‘fuselage’.
bisco
idk anything about the piglet aerodynamics tbh. if no one here can help, try contacting flite test.
I would try a few more flights and tell them about the 30 second problem if it continues.
I have read that you have to keep up speed with it, which requires power, but I am sure you should get a couple minutes out of it.
RBunch4468
in this video, it looks like josh gets 2:40 out of it. watch
Still a few more things to check, but ‘flying’ much better. Adjusting the rear angle of the legs and pinning them with toothpick tips to hold them at the prescribed angle offered the most improvement. It’s a fun toy… I can fly it to give demos, that’s about all I expect. Still turns right better than left. Needs pretty much full throttle to stay aloft. Flights are a little over a minute per battery. Good enough for what I will use it for. It’s fine…. Thanks for your responses.
