EZ Power Pack Pizza Box
L Edge
Our flights have a tendency to be brutally short, so we aren't really testing the FC board to its limits. I could put together a run stand and torture one to death, but since the build quality is inconsistent it wouldn't prove much.
I've been involved in designing and building other planes, but I wasn't joking or exaggerating when I said I don't fly particularly well. It isn't for lack of trying. I have a condition the impairs the creation of visual memory and severely (in my case, almost totally) limits any mental imagery. You could give an average 10 year old kid a transmitter and in a couple of minutes they would be able to fly the plane as well as I can after messing with them off and on for a decade.
I think I'm going to build a FPV for myself and see if I fare any better. The cost has come down to the point it isn't the barrier it once was.
That may be fun with FPV.
BadAir
So, we built a run stand and tried a few things today.
The Hammerhead Eagle i-Thrust 2.1 ran into a backboard and broke a prop. It fly very well, but I don't have another set of props. These came from the clearance bin of the local hobby shop. I was bummed because it flew so well and I haven't seen anything like it.
So, I tested the remaining 3" prop. 85% more thrust than the EZ prop on the 816 supplied with EZ kit. Maybe a tiny bit less stable a full throttle.
The only other prop on hand was a 65mm drone prop. I didn't have high hopes, but it easily doubled the output of the EZ prop. Too good to be true. Surely this will destroy the ESC. As luck would have it, one of our boards had lost its antenna, so we made ready to sacrifice him to science!
But he didn't die. In fact, if anything it was more stable than the EZ prop. So left the it at 100% throttle for 4.5 minutes. Voltage started to drop after 90 seconds or so and thrust declined steadily. The battery was warm enough to notice and that was it.
But I wanted the magic smoke. So I grabbed 4 fresh batteries and ran them back to back to back. 20 minutes with the only interruption being my changing batteries and binding the transmitter. The only result was 4 warm batteries.
So I told a student I'd buy him a Coke if could kill it using only the throttle. He used up two more batteries in a little less than 15 minutes.
The original battery was recharged by then so rechecked the thrust to see if we had accomplished anything. Same numbers.
So I ran it at full throttle for 30 seconds then reduced it to half and let it run. It shut itself off after about 6 minutes.
I swapped in the 8520 and went looking for big numbers like I was home from school sick and The Price is Right was on.
I started out slow and was happy to see there was none of the drama of the 816. I'd bump up the throttle, the pitch would change slightly and the new number would appear on the scale like it was engraved in stone. Again, and again and again. All the way to full throttle. I couldn't believe the number. I ran the test over and over. Always the same. Perfect and reliable, no drama. Less power than the 816. A good bit less.
Why? Because that's what happens when you run a 7.4v motor on a little under 4 volts.
Did you try running 2 motors per output? Run the motors in parallel.
You should be able to cut a length of wire equal to the length of the antenna on anothe board and solder it in. There is nothing special about the antenna othe than length.
Maybe it's me, but I don't understand why your trying to smoke a well running motor system.
Don't get me started about antennas.......
BadAir
I haven't yet. These tiny wires and connectors give me fits. I have some parts order and we absolutely will try.
BadAir
Abject failure:
