Aero_Knight
So I have gotten this far with my non detailed prototype build of an F-117 Nighthawk. Not glued and without the correct final bends hence the foam showing on the edges but I think it’s getting there. It isn’t perfect but I am currently debating on how to power it as it will dictate how I finish the tail section. I was originally going to make it big enough to house two small 30 or 40mm EDFs but my initial hand sketch template came out smaller than I imagined it would be although I kind of like the 17” length scale. So I am thinking of putting a mini swappable frame as part of the tail section and make it a push prop. Elevon setup and I am tempted to also use the vectoring frame to get some rudder control. Thoughts? Access to electronics will be via a bomb bay hatch style door.
UPDATE: (9-27-18):
So I spent some time modeling the design in CAD shown below and I have a much better picture of how to put together the now dubbed "FliteHawk". It will use a set of split surfaces with a special linkage to allow four servos to control the surfaces and provide pitch, roll and yaw control. An example of the setup is below but somewhat exaggerated and missing a tensioner. The rods sit on the middle links not through them...yet.
CAD Design:
Linkage Examples:
Prototype Images:
UPDATE: (9-27-18):
CAD Design:
Linkage Examples:
Prototype Images:
