F-22 Raptor Single 70mm EDF.
noahangel11
F22 Raptor 70MM Twin EDF DTFB RC Plane
John Flach (RC Skunkworks)
Specifications
  • Length: 1320mm (~52”)
  • Wingspan: (954.4mm (~37.5”)
Electronics
Power:
Batteries:
  • QTY-2 3-Cell 4000 mah Lipo batteries wired in Series for 6S (A 3s pack will not fit in fuselage)
Servos:
  • QTY-4 17G Servos
Receiver:
  • 4 channel Minimum
Materials
Full Plans:
https://drive.google.com/drive/folders/1SZV9FdDes3sXX5H1RKTeZ5I_C5yr4ORD?usp=sharing
Tiled Plans:
https://drive.google.com/drive/folders/1QjG7GbacU4To4w-Ij-zkMleBEZMtplEt?usp=sharing
Assembly instructions:
https://drive.google.com/file/d/1GkbtIE_s9gMr2xEe8IzO__gKtQwhIpz6/view?usp=sharing
noahangel11
So far I have made the initial design in Fusion.
This week I will make the flat patterns for cutting out on my 80w Laser. The model has vectored thrust. A total of 6 servos will be used.
2 aeleron
2 elevator
2 vectored thrust
noahangel11
Some pics of my model
noahangel11
Is that a plugin for Fusion.
Looking good! BTW @Mr Man uses Onshape to extract the skins off the 3D model for the 2D plans.
Is that a Fusion 360 plugin? I do it differently.
But always like seeing different techniques. My way works for me, and it’s easy, but I’m sure there are other ways that might be better.
noahangel11
An update on the F-22. I have been churning through making the flat patterns for the laser cut files.
I have only the canopy and some tail pieces to finish up. Looks like it will take about 8 sheets of foam board.
My laser can’t quite cut a full 20” x30” sheet of foam board. I loose a little bit of bodreder space, not much.
Unfortunately, the wing flat pattern requires a full sheet, unless I break up the wing somewhere.
You can see in the pic how the top 2 sheets are larger.
I need to revisit this and section the wing somewhere without compromising strength.
