Take the paper off of the next fuselage skin, it has a score part way through the sheet and that is the side to take the paper off of. The sheet faces with the score towards the rear of the plane. Using the marks on the leading edge of the sheet, make bends in the leading edge only, while adding a gentle curve to the rear of the sheet where it meets former F7. Use the edge of a table to shape the part.
Line up the 2 marks on each side of the sheet with the 2 marks on the previous sheet, and glue down the leading edge only to former F6.
Once that dries, glue the trailing edge of the sheet to F7, only half of the former meets the sheet. Press on the trailing edge where the score is, to follow the curve of the F7 former.
I noticed the EDF divider was not correct, as it should meet the skin, and there is a gap as shown in picture. I will correct the divider so that the skin will rest on the divider, in the final plans.
