Sorry guys, been a rough week.
So I did the AFT section as the front. Laid out the sides and the bottom, with 3/16" space for the fold. I needed to round the back sides and the bottom so I removed the paper to curve it nicely.
I put the wing on and thought it looked "ok". I've flown the F-22 with a flat wing and it flies "ok". I thought I could put a small airfoil in the wing.
I basically did the spar at 40% and used the Versa wing design, just scaled it down to meet my needs. It's awesome to use the building skills I've learned to add to the plans.
The Spar is just one foam strip cut to 1/2" wide and a small piece at the body end to give it some taper.
I also figured I'd leave the ailerons attached. For me the paint sticks better to the minwaxed plane, so less things I have to tape the better.
AND!
I just got these from Hobbyking. I have no idea if they will even work, but I was
maybe going to use them on this project. We'll see how much the plane weighs.
. . . more to come!
