chris398mx
I sent you the stlsWell, my library has one, so yes, I guess I do... Thanks!
How is the power comparison between similar size BDF or EDF. I’m having a hard time wrapping my head around this. If I can squeeze a 3” (76.2mm) BDF in a plane that is designed for a 70mm can I get acceptable power? I just ask because I can run a 3” 3052 with a 1408, but my 50mm edf is way bigger. Thanks,In the past I have posted progress on a 70mm EDF F18 I had been working on, but I feel this latest version needs its own thead. Hope you don't mind😁😁
After Flite Fest I got to talking with Josh about a new Jet that could take advantage of a number of power plant options. I have been busy with other planes but finally had a chance this week to bang out a couple prototypes.
This F18 is a redesign of my smaller F18. The goal witht he latest revision is to make a Jet capable of accepting 90mm, 70mm 64mm EDF as well as the new BDF(Ben's Ducted Fan)
I built two prototypes, the first with a pair of 90s and ine with a Pair of 4" BDFs.
I still need to finish up the tail of both aircraft. I am hoping for common components for all variants. You will notice that the one with the 9mm has added spars to handle the higher stresses.
Anyway, here are a few shots of what I have so far.
*** View attachment 141867 View attachment 141868 View attachment 141869 View attachment 141870 View attachment 141871 View attachment 141872 View attachment 141873 View attachment 141874 View attachment 141875 View attachment 141876 View attachment 141877 View attachment 141878 View attachment 141879 Doing this on my phone makes putting pics in proper order difficult
Gremlin 1106 on a 2" 4-blade prop, running on 4S. Mount it on aluminum fins. It spins up to 70k rpm and screams, generating about half a pound of thrust. But note that the motor gets hot, so it has to be mounted on steel screws to keep the printed spider mount from deforming. Someone with more experience could probably get more thrust out of it by redesigning the housing- I used a skinny seltzer can. Just note that you have to have a really fast ESC- BLHeli32 is pretty much required. I also designed an 1106 spider mount that gets folded from aluminum sheet, but that's designed for the seltzer can. Hopefully it provides some inspiration though. Here's a link to my Fusion 360 design for the 1106 EDF-ish-thing. https://a360.co/33ZVGYb I currently don't have access to the desktop program though, since it's not compatible with my Windows Insider build.I think we need some mini sized BDF jets running gremlin motors...
The basic concept behind the BDF physics-wise is to reduce the power output and increase the efficiency at the speeds we fly. If you're going 250 mph, then a real EDF would be more efficient. But we aren't. So the thrust pressure (ounces per sq. in. of prop disc area) is lower, increasing the effective efficiency, and the blade count is also lower, increasing the efficiency. Bigger prop with fewer blades generally means higher efficiency but lower airflow speed.How is the power comparison between similar size BDF or EDF. I’m having a hard time wrapping my head around this. If I can squeeze a 3” (76.2mm) BDF in a plane that is designed for a 70mm can I get acceptable power? I just ask because I can run a 3” 3052 with a 1408, but my 50mm edf is way bigger. Thanks,
Unfortunately it's not that simple.its so easy, diameter decides... a 110mm BDF cant be compared with a 70mm EDF
"Gremlin 1106 on a 2" 4-blade prop, running on 4S. Mount it on aluminum fins. It spins up to 70k rpm and screams, generating about half a pound of thrust.
Thats approx 50.8mm , 221,80g thrust
Banggood 11 blades EDF: 850g thrust
50mm EDF 12 blades 4s : 950g thrust
