Ok, then so long as I'm getting thrust out the back then the motor and prop combo is right?
You video would also seem to me to suggest inadequate thrust.
So
How much does your F22 weigh complete?
With an 7x3.5 prop the Turnigy 300 should give 420g (14oz) thrust at full power drawing just over 7A.
Something like an F22 needs a thrust almost equal to its weight.
An 8x4 prop is recommended for this motor with a 2s battery.
On a 3s it will be drawing significantly more current, likely more than a 500mAh battery can provide.
You might have to upgrade your motor system, if the specs here are correct.
But the main thing is getting the motor the right direction, and the prop the right direction, then you can go from there. Keep the weight down, build a new body if you have to, repairs can add lots of weight fast.
