I was setting up a versa copter for my brother and he was using a Turnigy 9x receiver. I own one as well but I no longer trust it with anything other than a small foam plane after having a number of crashes due to interference. So I made sure that his failsafe worked properly and it did. The motors shut down when the transmitter is turned off or loses connection.
This prompted me to check my own failsafe settings. I am currently using a Futaba T8J and a Naze 32 rev 6 to control my versa copter but I can't get the failsafe to work correctly. I have it set on cleanflight version 1.12 to 'drop' with pulse ranges outside my remotes input but I believe that the Futaba receiver is over-riding the naze failsafe. Instead of stopping when the remote is turned off the motors rev up enough that if it had props on it would lift off the ground and fly away.
Does anyone use a Futaba T8J or know a way around this problem to get the failsafe to work properly?
(I have tried using the CLI to make sure it wasn't the naze board by inputting set failsafe_throttle = 1000 so it was less than my minimum throttle but this didn't work either.)
I'm trying to get it to shut down the motors after losing contact.
