Fairly new - foam plans?
thecasualflyer
Hello,
I'm fairly new to this forum so I'm not really sure on where to find really anything, I have a project to build a large airplane out of either foam / cardboard / wood, my issue is, first, i need to have it like 1.5 m in length and 80 cm in height - so I haven't had luck on where to really get started with the building? I was hoping I'd be able to find some sort of plan where I just need to scale it up maybe? but even the printing would be realllly expensive, then stick it on cardboard to have the measurements then build it? where will I be able to find these plans? as I haven't really had luck, my other idea was to find a really detailed plan with every corner and side measured but no luck with that either...any advice is highly appreciated!
Hello,
The XL simple scout is an AWESOME XL plane, and it doesn't require any scaling!
Here are the plans: https://forum.flitetest.com/index.php?resources/ft-simple-scout-xl.289/
And here are the build videos:
... I'm not really sure on where to find really anything, I have a project to build a large airplane...
Here is the Plans section of the forums. Membersof the fourm post their designs here. https://forum.flitetest.com/index.php?forums/plans.106/
Here is SP0NZ's plan index of nearly every FT plane.
