@FL_Engineer for the simple scout it doesn’t matter. On some of the warbirds and other swappable planes, the two round holes need to be on the top to mount in the fuselage.
If you have the 4 screw option on the motor you are using it shouldnt matter. All you gotta do is turn the motor 90 degrees until the screws and the wires line up to where they need to be
I thought he was asking about the square wire hole being in a different corner. Which can happen depending on which side of the firewall you glue to the pod. Either way your good as long as the 2 round holes are at the top.@FL_Engineer for the simple scout it doesn’t matter. On some of the warbirds and other swappable planes, the two round holes need to be on the top to mount in the fuselage.
Your good. Prop torque is corrected in thrust angles built into the pod or the fuseThanks, that was what my plan was; just wanted to confirm I didn't need to correct for prop torque or anything.
Oh, I see. OopsI thought he was asking about the square wire hole being in a different corner. Which can happen depending on which side of the firewall you glue to the pod. Either way your good as long as the 2 round holes are at the top.
Yea the throttle should be progressive, to punchy and bad things happenMy biggest correction for prop torque, is taking off at about half-throttle. The first few flights, I went full throttle, and the prop torque imparted a significant bank. At half throttle, it rolls forward, the tail lifts first, and then it lifts off nicely.
I iron them under wax paper, you can push it back to the joint, I leave the wax paper on the plane till its cool then it peels right off, ive also used an old solder iron with a round blunt end, as its heating up you can form bumpy, sloppy hot glue, mine is adjustable , but you could unplug it when it gets too hotMade some progress last night; unfortunately it may be turning into a solo build 😐. Hopefully she'll get back into it when we get some paint on it... Lessons learned so far:
1. Josh is a wizard.
2. The sharper the blade the better
3. Don't use said sharp blade to cut all the way through the paper. Do use said blade to separate a horrible joint for re-glueing.
I think I've managed to keep my joints straight and I think it will clean up with a little sand paper and paint. What do you guys use for cleaning up smeared glue joints I don't always get a chance to clean them up before it cools (gun is 40w)
You can progressively drill them out using a drill and bits, start small and step it up a few times. As long as the hub will allow for it, Like the hole can't be bigger then the props center hub lol. Do you have pics?So I'm I'm still waiting on parts but I tried to test fit my props and apparently the output shaft is a couple mm larger than the center hole for the prop. I originally assumed they would be friction fit but now I see the motor came with a prop hub. Unfortunately the hole in the props I bought are not large enough for the hub or motor. Did I buy quad props buy mistake? Anyway to use these or should I just find a different prop?
I would just try to drill in the middle of the propeller. Then to balance it tape some sand paper on a table rev up your motor with the prop in and sand the tips of the prop to make it balanced.Here's the prop...
I'm starting to lean towards returning and buying something else. I could put them on the drill press and drill them out but it seems like a lot of work and I may end up with unbalanced/ compromised props. Any suggestions on cheap props for my 2212 1400kv? I'd like to order from Amazon if possible given the quick shipping.
YesI would just try to drill in the middle of the propeller.
NO! That's how somebody loses a kidney bro. That won't balance a prop but will make your tips even if anything.tape some sand paper on a table rev up your motor with the prop in and sand the tips of the prop to make it balanced.
99% of the props you buy off the shelf are unbalanced, causing vibration throughout the motor and into the airframe, wearing out things prematurely. You should be balancing new props before they go on any plane. In this case you have definitely got the wrong prop for the mounting application to the motor. The prop hub will support drilling it out, and on a drill press is ideal. I just didn't know what sort of size range we were dealing with so that's why I said "progressively". You will need to use the prop adapter and that would be the size you want to drill it out to. If you were to use the one bit the right size to get the prop to fit on the adapter then there is a higher chance the hole would end up off center and causing more imbalance issues. If you step it up a couple sizes at a time then you have a better chance of staying on center. Here I have a vid that might help...I could put them on the drill press and drill them out but it seems like a lot of work and I may end up with unbalanced/ compromised props.
I think the only real question left is, does it balance?
Please wear eye protection the first time you spin that.
