FB Stick is on the way
hotwax
This is my Great Planes Big Stick, powered by a 5065 motor and 6 cells 4000 mAh.
Great flyer, but not 40 size and not a swappable.
To power a 40 size version I need a 3536 motor or even bigger. My first step is to modify the powerpod for taking a bigger motor.
I added to the standard powerpod a second firewall some 10 mm longer .
The new firewall is only fitted with tape, strength comes from the 3 screws going through both.
The hole for the axle is enlarged.
Without the lugs you can't mount the nuts at the sides.
There goes the powerpod.
Space for a 2200 mAh 3 cell,
or a 2800 mAh 4 cell.
To be continued.
Werner
hotwax
I tested my basic construction of the wing building a wingtip
This looks good and I will proceed.
To be continued
Werner
hotwax
News of the FB Stick
After some cutting.
Parts for one half.
Time for servo and cable.
Servos will be screwed on.
Posterboard for the wingtips.
Two halfes ready.
Sorry no picture of the wingjoiners.
To be continued
Werner
aiidanwings
I am enjoying your build Mr.Hotwax. If you remove the paper from the inside of the fold, the board will have a smoother bend without much loss of strength.
hotwax
... If you remove the paper from the inside of the fold, the board will have a smoother bend without much loss of strength.
Hi aiidanwings,
thank you for your proposal.
I like the bends, as on the original "Das Ugly Stik", they produce turbulence, hopefully making the plane behave better at the edge of stall.
By the way, I can't remove the paper as with the original Adams Board, at my board bonding is much tighter. If I try, some paper stays on the foam and bending doesn't get smooth..
hotwax
The wing joiners left out above.
Fuselage with doublers attached.
B-Fold
Lockingbar will be glued in later.
Plywood bar takes the torque.
Stuffed with foamboard strips.
Lock for the powerpod ready
Could not resist ...
To be continued
Werner
hotwax
Thank you very much. I'll do my very best.
No more clips in the box
Elevator downstairs,
rudder upstairs
Tailfeathers come together
Hope it will last
I wasn't shure about the hatch. Balancing Shows, it needs weight up front
The servos are digital, so I go for 11ms
New motor is a 3548 1100 KV, prop 10 x 6E
CG is ok now
Ample room for the Rx.
It weights 1400 gr + ESC + Landing gear + Weels = 1600 gr?
To be continued
Werner
hotwax
After a sunny day at the flying field, not much progress in the workshop.
Detected a possible weak spot.
Made a fix.
Cured it (hopefully)
4 rudderhorns
1 mm steel and zipties
Lacking some elegance.
But hey, it's a prototype and hey, it works.
One more finger burned.
Werner
hotwax
I am entering the finals!
The material is Hobbycolor by Guttagliss http://www.gutta.com/html/fileadmin/user_upload/pdf/guttagliss_hobbycolor/Prospekt_9500239_Hobbycolor.pdf
You can treat it a little with your heatgun
and bend it at an edge. In this case it was my metal ruler.
Too flimsy for a landing gear but will prevent the wires bending backward. 3mm steel wire will take the load
Zipties are my special friends
Wheels 70 mm
That will do the job
Cheap parts from house installation.
for fastening the wheels
distributing the load
No rubberbands! Will be a medium to advanced trainer!
Propeller clearence is good
magnetic hatch
Blocks take more torque
Still swapable
Only the ESC is missing, weight with a substitute 1600 gr
We are awaiting one or two days of rain. Hopefully the ESC arrives soon.
I will report
Werner
hotwax
The parcel arrived today !!!
got crampt
A less powerful outfit. Hmm, I must build another powerpod!
Colour for the camera
It's raining
Werner
colorex
Rotor Riot!
Awesome! It's always exciting to unbox stuff :D
I got my packages a couple of weeks away still.
hotwax
Today is the day for the maiden flight.
A quick calculation says, that the black motors gives nearly 1 hp at full throttle.
This will give a nice hotrod, but I am here doing a medium trainer.
So I stepped back to this motor giving half that power using the same propeller.
I recomend using a plastik spinner for safety.
What a luck, it is a swappable!
Size is 56'' span, 46'' length, weight 1600 gr
Werner
